well...I actually broke down last night and took all the fan stuff I acumulated over the past few months and came up with a setup that works and I like..
here goes
Flex-a-lite 220 pullers (400-220 ) at jegs
the 0-260 degree thurmostat from advanced auto
Racetronix dual fan harness
I originally did not use the racetronix harness because...well I had no idea how to hook the thing up (No instructions included) and there is just crappy support for us hot air guys. I was using a basic fan harness till I melted the 30 amp fuse. Anyway I gathered up all my stuff and went to work. I stripped out the fan side of the racetronix harness leaving only the two 12v wires. Thick blue and thick white. The big ground and the thin ground were not needed and frankly confusing and stupid. I ran the fan grounds to the lower radiator support, though any ground will do. I connected the blue to one fan and the white to the other. Then I tapped into an ignition switched wire, in this case I have a heated O2 sensor and that has an switched ignition wire. Ran the wire from the switched ignition to the thermostat and then hooked the other side to the ignition wires on the racetronix harness. (small red, and small blue wires)....
The other side of the racetronix harness has 2 black (both ground) one large white, and one large blue (battery). I tied the thin black wires together and ran them to a ground screw by the battery (any ground point will do). Then ran the 12v wires to the positive battery. Total 1.5 hours including hooking it up and testing it before actually installing it.
This all sounds complicated but it's not. Once you strip out all the crap that is only usefull if you have an 86/87 from the racetronix harness, it works very well. Once it's all in simply crank up the engine, the fans will come on immediately...turn the thermastat till they go off, continue to do this untill they come on at the temp you want....The benefit of this approach if you can't see it already is if you use 2 thermostats you can turn on one fan at say 160, and the other at say 180....Actually the possabilities are endless once it is working. You can modify them to do just about anything.....
