So yesterday I was driving, gunned it a bit through an intersection coming out of the gas station. Yes stupid, car kicked out the rear and I got some knock on the scanmaster, in the split second glance that I took, it may have went up to 1.0 (i have the v2.2 chip in it). When the car started to go sideways is when the knock showed up, but I left off as soon as the car kicked out that much. I get to the next intersection in like 10 seconds and come to a stop, smoke spewing out of the tailpipe as if I was doing a immense burnout. There was no popping on the way home. Under acceleration the car did not sputter or pop and boosted fine and no smoke under acceleration. Coming to a stop is when the smoke shows up. If I let of the brake at a green light and cost through to the next block not touching the gas pedal and stop, smoke does not come out the tailpipe.
Took the turbo off and it doesn't look wet at all in the exhaust side, no shaft play any which way. Took off the doghouse and it looked wet. So I dug further and looked into all the air chambers going to the intake valve. Cylinder one chamber looked wet. Decided to take off the manifold and noticed coolant in that chamber above the valve. The intake manifold gasket looked fine, didn't look broken but sure was grimed up.
Long story short, can an intake manifold gasket leak coolant to the top of an intake valve even though it doesn't look bad?
