TheDoughboy
- Feb 27, 2002
I need to do a coolant change, I will use Distilled water & RMI for sure. It gets hot where I am at, So would I be better off mixing a 70% water/30% coolant? Just thinking that the extra water would provide more cooling
I know alot of people just do a 50/50 mix, I'm looking for a little more cooling power, I'm not to worried about the winter and freezing. What about 100% distilled water with Water Wetter and the RMI???
I am running a 160 t-stat and temps on the sm are 190-205 with the a/c off, when it's over 85 out. Never overheats or boils the overflow. The orig owner had the radiator rodded out. I want to see if I can get better results through a coolant change -vs- a new radiator$$.
Thanks for any help.
Ron
Ron
