1/4", that is what I thought. Since the car is a hybrid, I am not using the hard lines but it is 1/4". I have a baffling leak in the area of the pass- front corner of the tranny. It only leaks at WOT and difficult to tell exactly where the leak is coming from. It all started when I replaced the front pump and inserted quick-disconnects in the tranny lines. Before I pull the tranny again, I was wondering if the quick-disconnects were causing a restriction, could this cause pressure build-up in the pan forcing fluid pass the gasket or dipstick tube grommet? This is the 2nd pan and 4th attempt at gaskets to seal the pan and the grommet is new.
Any suggestions would be appreciated.
