- Feb 18, 2006
Pull a valve cover. If there is any milk on the inside, you found your problem.
SignUp Now!also did the car run coolant at all ?
Ok, guy here is what I'm going to do over the weekend:
- Repin the fans and have them hard wired to a switch also
- Put in a new water pump
- Put in a new 160 thermostat
- Seal up the shroud to the radiator
- May order some better Fans that make more CFM found some that will due 1750 each.
- Pull one of the valve cover.
Any updates?Round 2 of testing will go today. The temp is going to get up 90 today and I will see how she dose today in so stop and go driving in town. Wish me luck![]()
Maybe I missed it but what fans are you running?The car did good, had a few high temp a few time in the 195 but dropped back down to the 178 on the scan master and 180 on the gauge. I think I need better fans on the car that pull more CFM. Then it will cool better I think, I also looked into a new shroud do to the fact that I made my own, on base at the hobby shop. I hope that it keeps up the good cooling when I put the new Stroker in the car.![]()
A new record!!! A quadruple post, that must be good for at least four trophy points!
keep up the good work.![]()
