Stage II (Vari-Cool Controller kit)
Sells for $499
Our controller has the following features:
Serial interface (ability for you to custom tune if you wish, but NOT required)
Simple to use, ready to use out of the box (no computer necessary)
Ability to run using your vacuum/boost line, 0-5V (maf/tps) or BOTH at same time (2d mode)
1-30 psi adjustment for start boost, 1-30 for full boost. You can run 60 psi boost pressure with this
10 position tuning factor will change the duty cycle of the pump. This allows you to add more flow or reduce flow on demand. The amount of flow will depend on many factors including nozzle size. This makes a great feature to be able to fine tune if necessary.
Green Light to show current condition.
Fully programmable
Many advanced features including ability to change min pump pressure, max pump pressure, use custom maps, datalogging, etc.
Upcomming coolingmist commander can be attached to this unit to program the unit and display values.
Their website is: Water Injection systems, methanol injection systems, Coolingmist
Comes w/everything pictured
$299 shipped
accept Paypal(add 3.9%)
FRED
Sells for $499
Fully programmable
$299 shipped
FRED
