Not sure if you were referring to Earl's post or mine, but for those who don't want to understand the science...
1. The value for "h" inside the engine will increase.
2. The value for "h" inside the radiator will also increase.
1. It is not inherently obvious whether removing your thermostat will result in a lower or higher coolant temperature. "It depends."
2. The engine cooling system was designed to have the restriction of the thermostat in place, so I recommend keeping it.
Q = h * A * deltaT
"Q" is the amount of heat transfer
"h" is the "heat transfer coefficient" (more later)
"A" is the surface area of the piece of metal
"deltaT" is the temperature difference between the piece of metal and the coolant
Mike
mgmshar,
Thank you for your informative posts and your efforts to enlighten us further on this subject.
I've had some thoughts that seem contradictory to your assertion that this matter would require further testing and was wondering if you would feel free to weigh in on your thoughts of what I write below. I think that to consider the effect of removing the thermostat, one needs to use your equations buy first looking at an idealized steady state condition of a TB traveling down the highway at constant speed with thermostat installed.
By the definition of steady state, coolant temps and engine speed will be constant and the heat transfer rate "Q" will be the same between the engine and coolant as it is between the coolant and radiator (After the car is warmed and coolant temps are constant).
For our purpose we must expand on your definitions to include:
T_amb - "Outside ambient temperatures"
T_eng1 = "Average temps of metal in the engine"
T_coolant1= "Coolant temps as read by gauge, scanmaster or whatever"
Note that a "1" in a variable indicates the state of the thermostat being in place where a 2 indicates removed thermostat.
So,
Q_ eng1 = Q_rad1,
By defining the average engine temperature as T_eng1, Re-writing the above yields,
h_eng1 * A_eng * (T_eng1 - T_coolant1) = h_rad1 * A_rad * (T_coolant1 - T_Amb) (Steady state, cruising down the road with thermostat). (1)
Now for arguments sake, assume the thermostat is instantaneously removed... You only have to look at the radiator side of the equation to see what happens:
h_rad2 * A_rad * (T_coolant1 - T_Amb) = Q_rad2, notice that Q_rad2 > Q_rad1 because h_rad2 > h_rad1.
In other words, and as Earl was saying, the heat transfer through the radiator has increased. I think it can be shown that this change can only do one thing... lower the coolant temperature unless something crazy is going on.
The new steady state is determinant by assuming constant heat transfer into the system (Q_eng1 = Q_eng2) (2). This is true if the engine efficiency is independent from the operating temperature, so probably only valid for small temperature changes, but still valid to show if coolant temps decrease.
The new steady state is written as:
h_eng2 * A_eng * (T_eng2 - T_coolant2) = h_rad2 * A_rad * (T_coolant2 - T_Amb) (3)
by solving (1), (2) and (3) simultaneously we can solve for all unknowns: T_eng1, T_eng2 and T_coolant2.
Doing so yields:
T_coolant2 = T_coolant1 * h_rad1 / h_rad2 - T_amb (hrad1/hrad2 - 1),
so conclusively, T_coolant2 < T_coolant1 when, h_rad1 < h_rad2 and T_amb < T_coolant1 (which are normal conditions driving down the road).
This proves that, under normal conditions engine coolant temperature will decrease when heat transfer coefficients increase, and is what earl has been saying from the start. Because, heat transfer coefficients increase when flow increases, removing a thermostat should make temps go down. This is why prof. earl took
offense  to issue with the opposite notion in the first place. To my knowledge he did not dismiss people who said that it happened to them, but he instead pointed us to other things that might be happening, like heater hoses collapsing and such which would actually decrease heat transfer coefficients.
Please if you wouldn't mind taking some time to clarify the math, we'd be much obliged to learn more on this topic.
Bryes
