Pablo,
I will not promise you that we are perfect, but I will say that we do our best to provide customers with data on how our product works. We have a video section that has more than 25 videos. Here are a few.
This page details our stage 3D. The kit injects based on Air Temp, boost and RPM. Its a precise kit due to the graph set up below. Most kits on the market have a MIN and MAX knob, some have a tune. But you really have no control over how much it sprays other than giving you a linear output based on a single input. For those that want something better and need more control we can do 2 or 3 inputs if the customer does not want a single one.
CLICK FOR VIDEO
This one is our grid using boost and RPM in a 2D mode. Using this grid you can make sure you have exactly what you need as far as flow.
Lets talk about what happens with our kit, when you change min/max/tune. We have a real flow sensor to show you.
Here is the tune knob being changed. You will notice the max flow increasing. We kept the boost steady, but changed the tune to show you at any set boost level the under curve will change.
CLICK FOR VIDEO
Changing the MINIMUM button and keeping boost steady.
This video shows what happens as you change the Min knob higher or lower on our Varicool controller. The difference between the MIN and MAX knob will determine how fast the system injects. On this video the GREEN is minimum knob, RED is MAX. light blue is flow and white is boost. The MIN knob is the PSI you want the system to start injecting, the Max is the PSI you want it to be on full flow.
CLICK FOR VIDEO
This shows you what happens as you change the Max knob higher or lower. On this video the GREEN is minimum knob, RED is MAX. light blue is flow and white is boost. Notice the flow increases/decreases. Where the min/max are set in relation to each other help to determine how fast or slow the system will progress.
CLICK FOR VIDEO
Here is our system responding to boost on a slow spooling vehicle:
This video shows the progressive nature of our Varicool controller. You see in a slow spool how fast it reacts. Notice as boost increases, so does flow. Flow is indicated by the thick blue line, boost is indicated by the white line.
CLICK FOR VIDEO
This video shows the progressive nature of our Varicool controller on a fast spool. Flow is indicated by the thick blue line, boost is indicated by the white line. Boost comes on fast and our controller matches it. VERY fast reaction.
CLICK FOR VIDEO
Now getting to response time with RPM...how fast can our system respond to RPM signal? Here are two vids to show you.
CLICK FOR VIDEO
Here is our Super High Speed Valve using a Frequency Based MAF singal. Notice the flow increase with MAF.
CLICK FOR VIDEO
We do extensive testing on our product. The world of meth injection has advanced beyond simple analog devices, today with the right technology you can run more than one input to insure proper flow at RPM VS BOOST, etc.
David
