core / rad support bolts
turbobooster
im putting back my core / rad support and i didnt write or take pics of how the 2 long bolts with the bushings and washers setup go when attached to the frame of the car so does anyone have a pic or know of drawing on here i can look at? or maybe one of u guys know how this bolt should go back in correctly thanx
Here ya go...
http://www.energysuspensionparts.com/Installation_Instructions/Energy_Suspension/17132.PDF
This for the poly bushing kit, but is basically the same.
What they are calling the body in fig 1 is the core support.
Look at position number 1. You want the biscuit with the metal sleeve coming up through the frame into the core support. The core support goes on top of that and the cup half of the bushing goes on top of the core support. Do yourself a favor by leading the lower biscuit in with the mounting bolt and about a 10" extension.
I'll take pics tomorrow if you need more info.
Jerry jr.
thanx waco but for some reason i cant access that link so energy suspension sells just these bushings for the core support? some pics would b nice to have a visual i appreciate it
