meenkeene518
 - Apr 4, 2007
Hello all,
As my title says id like to know the proper way to do this. Car runs fine but the lines routing are sorta a mess, but as of now just the external gate is hooked to the 2nd port on the vacuum block, and the map sensor goes to the vacuum brake conversion nipple on the other side. Since i'm not using that conversion one any longer, i was going to switch back to the standard 5 port vacuum block. Can you tee the map sensor line with the external gate and a external boost gauge, making it a 4 way split instead of the normal 3 way split, then run it into the correct port on the block?
Thanks for the help!
