Could my oil leak be coming from the Turbo Oil Drain Tube ?
transampacecar
HI
I have a small puddle of oil that lays on the top of the block just above the water pump and below the thermostat housing. I was wondering if the Turbo Oil Drain Tube would do this if it was bad ???
Here is a photo of the tube I am talking about.
Do these go bad and leak ? Do you think that this is the cause of the oil puddle on the block ? I dont think the oil is coming from the valve cover either.
http://secure.johnsperformance.com/images/large/large-drain.jpg
Thanks for any help
