couple more Buick engine goodies
FastRegalWE2
Wish I had another Buick!
Buick parts eye candy..
Looks like your going to be building a very nice motor! Mind giving us some details on the build-up?? :cool:
Red of Eastern Virginia Turbo Buicks is putting it together but, its basically going to be 70 P Trim ported stock intake, 83# inj, 70mm plenum and 70mm TB, ported GN1's, 215/220 roller Revolution X cam, .040 over Diamonds, K1 rods, Eagle crank, Total Seal rings, FAST system, Jet Hot caoted ATR headers and DP, Dual nozzle alky (Razor's).
Thanks for sharing your combo.. Sounds like a very nice setup that should easily be low 10 sec capable! :)
We are hoping for some 9's. Car has been lightened a little, aluminum supports, no sound deadner, removed front sway bar, light weight starter, etc. MT DR's, CK Stage 2 trans with Stage Rite brake, Metco uppers and lowers, HR Parts rear bar and 1 bag, Precision FMIC, Moser axles, aluminum drums, TA Perf rear girdle, aluminum 3" driveshaft, BHJ balancer, JW flex plate, all internal balanced :biggrin:
You definitely have the right parts to go 9's with the 70P.. If I remember correctly Red's ran 133-134mph with that turbo on self ported stock valve iron heads and with a smaller cam (204/214 flat tappet) than you have!
Good luck with it and please keep us updated with pics as well as some video from when you take her to the track:biggrin: :cool:
I saw Red Fri night in Richmond. We have about identical cars. Nice looking parts!! What downpipe are you running?
