CPS bad...can i get one?
bucky
My buddies 84 GN would not start yesterday.Just turns over.We have figured that the CPS is bad.I am having no luck finding one for this car.Will the 86-87 part number fit?Anyone know where to get one for the hot air car?
CPS
Before you replace it, be sure that it is in correctly and adjusted.
I had installed mine, and placed the vanes between the metal
plates--it looks as though it should go there--but it doesn't.
The vanes rotate through the plastic part of the sensor--with
a .030 gap.
Napa should have them and O'Reilly's should carry them...
You shouldn't have too much of a problem finding the crankshaft position sensor...Make sure you tell them it's for the turbo'd motor, Vin 9 engine code...
