1dollardog
Are we there yet?
- Jan 5, 2007
I was trying to replace the crank sensor on my 84 ttype. I bought a used one from a respected member of this board but when I got it it wouldn't exactly fit. It was clearly the same bolt pattern but the part with the fins or grooves is about 1/4" or so larger than the one I took off. The new one will not go back on due to this. The grooved section is hitting the balancer piece just enough that it won't allow it to slide over the center peg and be bolted in. Did they make different crank sensors? The one I bought is clearly different than the old one in this area but seems to be the same part (if that makes any sense). The grooved piece on the new one is clearly aluminum and the old one seems to be sort of a coated plastic in this area. If anyone has any experence with this I would greatly appreciate some help.
Thanks,
Steve
Thanks,
Steve
