Rodney87GN
- Feb 1, 2004
Cool, good luck on the engine build! I live quite a ways down from you in Mira Mesa. When you get it done I'd love meet up with you at Barona. Keep us posted on your progress.
SignUp Now!Bringing this thread back...
First of all....Thank you Pablo and ttypewhite (for the diagram) for both your efforts and help!
I finally got around to installing this LT1 pump setup, and let me tell ya it flat out works! Now when I hit 26+ psi I no longer get oil seepage from the oil pan, or oil coming out the dipstick tube. Before I had 2 open breathers and blocked the PCV. That worked good as far as not getting oil out the breathers....but sometimes a little oil was coming out the dipstick tube and always getting past the oil pan gasket from excess crankcase pressure.
Initially when I installed it the system didn't work properly. For some reason I was blowing the 20 amp fuse on the Racetronix harness every time I got on it. I guess when the smog pump ran it was pulling too much amperage and would blow the fuse. I knew it stopped working because I can see the oil smoke cloud behind from the oil blowing out the dipstick tube onto the crossover pipe.So I put in a 25 amp fuse and works great now. Otherwise it was easy to install, the Racetronix harness is well worth the money. The hardest part is figuring out where to mount all this stuff.
I admit though the catch can is a bit overkill now. Not a drop of oil gets to the catch can. I'm using Moroso breathers and I believe they have a built in oil/air separator. I also made the stock PCV operational again...the oil is much cleaner now. I don't think I'll ever run a street car without a PCV again.
can some one give me a auto parts ball park figure( price )on a lt1 pump.
That is excellent news, good for you. I had my setup just like yours at first until I got that $365 ticket for venting crankcase pressure into the atmosphere.Its a very stout setup, I like it a lot. I worked with Racetronix on testing of this whole evac idea, and they made it seemless for me to hook everything up properly and see instant results. It also makes me feel good hearing and seeing your results too. Thanks for the feedback.
I'm thinking about just getting rid of the catch can now since no oil is making it there anyway. Did you just vent the crankcase pressure back into the intake? Or do you just run the outlet side of the pump with nothing attached?
