Gee Pablo, you do an informative post with lots of details, pics and good info, all for the "privilege" of getting bashed because someone does not think it is necessary or ????
You did a great job, thanks!:smile:
We do LOTS of race engines for lots of racers, and a lot of the faster cars have a vac system of sorts even if they are not turbo charged.
Actually most GN owners remove the factory vac system - the pipe from the passenger valve cover to the turbo inlet.
When you take 1960's technology, like our V-6, it takes a different approach and solutions than the 21st. century performance cars that were "born" with computer pollution controls.
With the turbo Buicks, from low 11's and faster, crankcase becomes an issue be it leaking oil, or increased performance, or both.
Based upon personal experience with low 10 high 9 sec. GN's, I have seen 1 to 2 tenths improvement with a proper vac system. Just a side note, just a few weeks ago my vac pump quit on a 10.0 run and blew out a VC gasket at the top end [at 20 psi boost].
All of our 8 and 9 sec. engines are built to run with a vac pump. This also applies to most of other brand engines built to run these speeds or better.
A boosted engine runs stupid high cylinder pressures, even if it is for a second or less, and this equates to higher than normal crankcase pressures. I have seen many street driven GN owners complaining about a rear main leak or VC leak when it is actually oil from both after market breathers leaving a small trail of oil.
Certainly the imports, and domestics, have developed better ways of crankcase pressure management the Buick did 40 years ago. We were lucky to get a 90 day factory warranty on our cars, and certainly NEVER 3 years [or 5 years or even lifetime!].
So Pablo, do not be distressed by posters with "more internet" experience than what we have and do - working on 20+ year old turbo Buicks to improve them.
