Im looking to relieve crankcase pressure and have a few ideas:
- Pull vacuum from turbo inlet. Create filter/drain system that runs to valve cover or block
- Wire an electronic pump(s) (such as a LT1 smog pump) with hobbs swich that turns on under boost. Run to valve cover with filter/drain system.
- Put fitting in exhuast that will pull vacuum and run to valve cover.
I do not want to run a belt driven pump since I drive on the street a lot. For those of you who have ran a crankcase vacuum setup, please post your results and experiences.
Thanks.
Thanks.
