Crankcase Ventilation - A little research I just did
BJM
Senior Member
It all started when I put my car on a dyno. At the end of each pull a puff of oily smoke would waft out from the valve cover vent on the passenger side.
I never liked disconnecting the stock tube from the valve cover to the turbo, but like everyone else I didn’t want any oil going through the intercooler. I have been plagued by oil leaks and I find more oil comes out the more I get on it.
I performed an experiment on my car today. I put a ¾” heater hose on the turbo inlet bell opening. I ran it into the car and went driving. At idle there was no noticeable flow into the tube and the BLM value didn’t change whether I plugged the line or not. As soon as I stepped on the gas the tube began sucking in a lot of air. At 10 psi the tube was whistling with air going into the engine. The BLM numbers adjusted only a minor amount. My “thumb over the end” vacuum gauge tells me the suction pressure is about 0.5”-1” of Mercury. With the restrictive stock air cleaner the suction would have been greater. The cool thing was holding the tube when the turbo farted; it’s a pretty loud sound when it’s in your hand. You can really feel the air push back out while the flow reverses out the compressor.
Next, I connected a tube to the valve cover vent hole. At idle the flow was being sucked in by the PCV valve. Plugging the tube, the crankcase pulled a vacuum of about an inch or two. As I rolled into the gas, the inflow increased. At medium-low throttle the flow stopped and at medium to high throttle considerable blow by was pushing out of the engine. I made the mistake of plugging the hose a couple of times while it was blowing smoke and managed to blow a lot of crap out of the dipstick and onto exhaust manifold.
The turbo inlet has the potential to flow a lot of air, and it does so at the right time too. I am planning to figure out some sort of filtered catch can between the engine and the turbo inlet to keep things clean. The Buick engineers hooked it up for a reason; they just didn’t put enough capacity in that little black sponge thing.
Anyone else tested this? I am curious if my engine is typical or not in the amount of blow by.
I never liked disconnecting the stock tube from the valve cover to the turbo, but like everyone else I didn’t want any oil going through the intercooler.........
............The turbo inlet has the potential to flow a lot of air, and it does so at the right time too........Anyone else tested this? I am curious if my engine is typical or not in the amount of blow by.
Just pulled one of my race motors that was run for the past year with a breather from the valve cover to the compressor inlet. After initially hooking it up his way, LOTS less oil was being forced out of various openings after each run. Not tore it down yet, but no oil in the I/C piping or plenum. Of course the PCV is plugged too.
We felt the high crankcase pressures at high RPM's [over 6000] was costing horsepower but did not do a before/after test.
For a street-driver, I would think an evac pump would be the way to go. When allowed on a race car it would be great too. A bigger, better filter, possibly with an oil trap, may work well for street use, much better than just a vent.
The big thing for me right now is I think my oil pan gasket is blowing oil. Its my winter project for now so I live with it.
I am looking for a source for a good oil separating catch can.
BJM, have you run a leakdown test on your motor to see what kind of percentage of blowby you are getting???
I don't have a leakdown tester. Overall the car runs well and is not high miles, 55000 miles overall. I should do that though. Good idea.
