NEWCHAPTER
Need Speed
- Jun 8, 2003
Okay here is a long story, while adding the new stuff I did the top engine cleaning and while it was running it suddenly quit so far this is what I have done
1) replaced camshaft sensor with new one and caspers led cap
2)new spark plugs
3)new spark plug wires
4)changed oil to royal purple 10w40
5)replaced crankshaft sensor
6)drained gas tank of gas
7)gutted cat
okay so after I replaced the crank sensor, it fired up and was running... took it to work the following day about 35 miles ran fine... started it up to go home as I was driving I noticed it was hesitant with light acceleration.... so I thought maybe the cat was clogged so I gutted it... maybe bad gas drained tank to almost empty and added a bottle or 104+ octane boost... adjusted crank sensor to make sure it wasnt hitting ...... I have run out of ideas
2)new spark plugs
7)gutted cat
