cross over tube came off.......
TA2SLOW
How are you guys keeping the cross over tube from popping off? Will two part epoxy hold it? Or something else?
Are you talking about the 1/4" tubing under the valve body? Mine is press-fit. Just curious, but what symptoms were you experiencing?
There should be a retaining bracket on the bolt for the manual detent roller which holds the signal pipe into the valve body. It
is shown in Figure 7A6-237 of the ATSG 200-4r manual revised
edition.
Well my symptoms were, tranny wouldnt shift under full throttle on the 1-2 shift under full throttle and 2nd was starting to slip. Did a pressure ck and had only 90-100psi in 1st and 2nd with full TV.
edition.
I dont think mine ever had that, since someone else had once rebuilt this thing once before i got ahold of it. It also had 2nd gear burned out when i bought it, maybe not having that bracket was the problem the whole time.
edition.
Yeah, I'd forgotten about that... :eek:
Red Loc-tite the ends in, uasually works well.
