I've just spent about 6 hours doing crossover pipe work/replacement and thought I'd post my observations so that other people don't have to go through the same torture as I...
- The stock crossover pipe will NOT fit if you are using stock headers AND header gaskets (Felpro 1400). The gaskets space the headers out to far from the head.
- The ATR crossover pipe (86-87 Buick) is meant to be run with header gaskets (confirmed on phone 5/10/02).
- If your ATR crossover has a wicked exhaust leak (probably will), ATR has these thin, circular exhaust gaskets. They recommend that you use two per side. The gaskets are cheap (about $10 a set), but next day air ain't ($27).
- These gaskets SUCK! They aren't shaped to fit in/on the crossover (ie: not like the stock turbo exhaust donut). Unless you use tape or something, you have to magically balance them on the crossover pipe as you lift it and bolt it in place. Then, you hope & pray that they didn't shift out of place (they probably will).
- After a heat cycle, these gaskets will compress slightly and require you to jack the car up again and re-tighten the crossover bolts. That's always fun, right?
- After this, the gaskets will probably blow out. Within 20 minutes of hard driving (trying to dial in car) I blew out BOTH gaskets on BOTH sides of the crossover. WTF?!?!??!?!?!
- End result - I've taken the ATR crossover off and will put the stocker back on. But first I've got to unbolt the headers and remove the header gaskets, then bolt the headers back up.
AGGGHHHHHHH!!!!!!
-Banning.
AGGGHHHHHHH!!!!!!
-Banning.
