Crower roller lifters?
1fastgn86
Will Crower CHEVY HI-SEAT OFFSET ROLLER LIFTERS
.842" DIA. OD.
PT. NO. 66275-16
CHEVROLRT 265-400 V8
.180" OFF SET FOR SB CHEV
Will these fit our V6?
They WILL fit, but they have a .180 off set so the push rod doesn't sit centered in the lifter. Why would you want these? StageII engines "MAY" benifit from these lifters. They are also a solid lifter, so I am assuming that you are buildig a stageII?? Post this in the StageII section to see if anyone has tried these lifters. They also do not have a full shielded bearing either, and will cause an oiling issue if not used with due care and caution with set-up and base circle design. What issues are you having now? Call Dan @
DLS (219-956-3653) and talk with him on which lifter he uses on his StageII stuff. Just buy your StageII valve-train parts from him. No need to re-invent the wheel.
Just use the Crower full-shielded solid roller lifter that TA Performance sells (part # V1413-STK). Using these lifters you should not have any problems with oiling. By using a semi-shielded or unshielded roller lifter, then you have to get a small base circle cam and be careful on the lobe lift because you will unshroud the oil gallery in the lifter bores and loose oil pressure. This is for a 109 block. With Stage blocks this is not a concern.
Billy T.
gnxtc2@aol.com
