Hi everyone,
My cruise control was working, Now blowing the 5 amp fuse.
Here is what I did so far
Baffled at this time
- car running , but not moving. move the slide switch to on , acell , and back to off. Does not pop the fuse . But when I drive and try to activate , it pops the fuse
- Disconnected the servo , buzzed it out ~42 ohms for the two solenoid's and ~23 ohms for the sense . No shorts to grd or two each other pins on the soliniod . left it disconnected drove it , popped the fuse.
- Buzzed out the wires back to the control module , Module unplug , no shorts to grd. Module unplugged , does not blow the fuse on test drive.
- Stalk plug going to double check but.
