cruise control went out
saltydog
My 1987 GN has the cruise control option and it was working fine. I just had the powermaster replaced and now I have no cruise control. Did replacing the powermaster unit have something to do with why I now have no cruise control?
Check the cruise cutout switch that is mounted under the dash, against the brake pedal arm. It probably needs to be pushed in some more.
Yes you probably mis-aligned or mis-adjusted the brake switch on the pedal, or the shop did. ;)
There's a switch for electrical as well as vacuum cutoff that must be pushed up against the brake switch with no pedal apply.
When you push the pedal down it shuts off the cruise.
Check there first.
