cruise control
insane6
Any idea's where to start, cruise works, light comes on ,tapping down 1 mph works , but when you tap up 1 mph cruise shuts off
also at cruise ,say 65 mph I fell surging up and down slightly. :confused:
I'd check the functions of the switch first.
Maybe the momentary up switch isn't working and activating the shut off instead.
Resume/Accel. is the yellow wire out of the stalk and steering column and the gray with black stripe on terminal M of the cruise control module.
Should have +12 on it when you tap up the speed momentarily.
If you do an OHMS check unplug the stalk flat connector from the socket next to the steering column and test between the yellow and blue wires for continuity when you hit the accel. button.
