4 49-blues Active Member Joined May 30, 2001 Dec 4, 2013 #1 Any one know formula for figuring cubic inches? My motor is a 4.1 block bored .020" to 4.020", 3.625 " crank, 6.350" rods.
T tbone87 Well-Known Member Joined Sep 12, 2012 Dec 4, 2013 #2 Go to wallaceracing.com and u can figure everything!! I downloaded the app pretty neat. Posted from the TurboBuick.Com mobile app
ttypewhite Well-Known Member Joined Oct 1, 2001 Dec 4, 2013 #4 You would be close to 268 cubic inch provided you have stock deck height.
P PSID6 Active Member Joined Sep 6, 2011 Dec 4, 2013 #5 Bore x Bore x .7854 times stroke times number of cylinders
4 49-blues Active Member Joined May 30, 2001 Dec 4, 2013 #6 Yes pretty much stock height. Wallace racing says about-468 cubes- something ain't right?
4 49-blues Active Member Joined May 30, 2001 Dec 4, 2013 #7 16.16 x .7854 x 6.350 x 6 = 483- what's wrong?
T tbone87 Well-Known Member Joined Sep 12, 2012 Dec 4, 2013 #8 I got 278ci or 4.5 but I not the smartest either Posted from the TurboBuick.Com mobile app
pacecarta LOGGED OUT Staff member Joined Aug 1, 2003 Dec 4, 2013 #9 6.35 is your rod not your stroke and you asked cubes the rod length has nothing to do with it nor does deck height your stoke is 3.625
U USMC_Turbo6 Well-Known Member Joined Dec 13, 2009 Dec 4, 2013 #10 276.06 ci or 4.5 Posted from the TurboBuick.Com mobile app
4 49-blues Active Member Joined May 30, 2001 Dec 4, 2013 #11 Thanks- I knew I was doing something wrong. What's the correct formular?
4 49-blues Active Member Joined May 30, 2001 Dec 4, 2013 #12 Got it thanks-16.16 x .7854 x 3.625 x 6 = 276 cu in
R rag231 Well-Known Member Joined Apr 30, 2005 Dec 4, 2013 #13 Your block is actually bored more than .020, it probably didnt start out with a 4.00 bore new.
4 49-blues Active Member Joined May 30, 2001 Dec 4, 2013 #14 I got it at 4.005, it is now bored out to 4.020".
R rag231 Well-Known Member Joined Apr 30, 2005 Dec 5, 2013 #15 I guess it took a lot to clean the bores up.
4 49-blues Active Member Joined May 30, 2001 Dec 5, 2013 #16 Whatever Bobbie at RPE thought is alright with me! There was actually some minor scratches that I couldn't even see until he brought it to my attention- you don't argue with perfection, he is the expert and I'm very happy with the outcome!
R rag231 Well-Known Member Joined Apr 30, 2005 Dec 5, 2013 #17 Of course, an RPE motor should exceed all of you expectations.
