Recently bought a (low mile) built 109 long block with stock compression je's, race ported iron heads, and a custom grind roller cam. The motor was built by a reputable buick shop and I was provided with the build sheet. the custom ground cam specs look rather uncommon to me which are: hyd roller 205int./222exh., lobe separation 108, degree intake lobe 104, cam lift 323int.,and 345exh. (so with 1.55 roller rockers I figure 500 int. valve lift and 534 exh. valve lift).
Intake opens BTDC @ -2 degrees
Intake closes ABDC @ 27 degrees
Exhaust opens BBDC @ 42 degrees
Exhaust closes ATDC @ -2 degrees
With the exhaust duration (222), and valve lift (534) being sooo much bigger than the intake is it best to swap out this cam with say a roller 210/215 or 206/206? The builder advised me this cam grind is used for street applications and has much more torque than hp. Also mentioned that this cam has a steady power curve as opposed to a peaking power curve. I currently run a fmic, 60lb injectors, 3.5 maf, alky, turbonetics te-60 (63 exhaust housing), thdp, and a pat's 3200 10'' converter. Looking for something in the 10.50's range. After reading several posts on boost pressure and exhaust pressure (exhaust pressure usually being 2X boost pressure it has me wondering. Any suggestions would be appreciated.
