T turbobob924 Member Joined May 28, 2001 May 16, 2010 #1 well I decided to build a custom drivers side header. The stock one gets too close to my steering in the Porsche. This is the mock up. The steering shaft goes thru the header. Attachments photo1.jpg 67.3 KB · Views: 255
T TurboBuRick Moderator Staff member Joined Feb 18, 2006 May 16, 2010 #2 Looks good Bob! :biggrin: Snap some pics once they are welded up.
T turbobob924 Member Joined May 28, 2001 May 17, 2010 #3 Thanks. I need to lots more test fitting before final weld-up. Total PITA
T turbobob924 Member Joined May 28, 2001 Jun 3, 2010 #4 Header is all done. It came out nice but.... The flange warped a little so now I am worried about leaks.
WarWagon Caustic Cacophony Joined Mar 10, 2007 Jun 3, 2010 #5 turbobob924 said: Header is all done. It came out nice but.... The flange warped a little so now I am worried about leaks. Click to expand... Just get the flange milled until it's true. Then you know it's going to seal and you don't have to worry.
T turbobob924 Member Joined May 28, 2001 Jun 5, 2010 #7 Here is the finished header next to a stock one And a shot of how the steering shaft goes thru the header. Attachments header clear to steering.jpg 56.7 KB · Views: 149 header vs stock.jpg 55 KB · Views: 145
WarWagon Caustic Cacophony Joined Mar 10, 2007 Jun 5, 2010 #8 Fit's good nice work straightshot. Get that flange milled flat.
C charlief1 RIP Charlie! Joined Sep 20, 2007 Jun 6, 2010 #9 Looks almost like my old KB NA headers Bob. Looks good though.
T turbobob924 Member Joined May 28, 2001 Jun 6, 2010 #10 thanks guys. I spent a lot of time getting the config to clear the steering shaft. In the end it is very much like the TA headers except the back port is flipped close to the block rather than on the outside.
