Custom headers?
tobuyitright
I am needing to make a set of headers. What are the best tube size for primaries, and cross-over. Also does equal length tubes matter? Thanks
Primaries depends on the size of your exhaust ports and/or whatever flange you find to use. I think RJC has all the flanges you need so just use the same primary size of his flanges. I would also use the crossover size that fits the 3 bolt flange the best so there isn't much fabrication involved. Anything 2 inches or better for each side after the collecter or 3 inches if merged a ways before the turbo flange should be plenty. I can't remember off hand what size the turbo inlet is.
Equal length won't make any difference on a turbo motor so just do what fits the best and easiest.
