Well since i have decided to box my frame my custom lines i had made by Inline tube will not fit any longer so they are up for sale. Here is what i have 1/2" feed, 3/8" return and the stock sized 5/16" vent lines the lines are bent to factory specs and fit pretty good considering the bigger size but they are bigger and take up more room!
By doing the line upsizing i had to change the filter and did a FST rpm300 which is a 4 micron filter and water seperator and flows 300GPH with a scre on filter makes it easy and it fit very well in the stock location with two new holes drilled! I might keep the filter but being i built the lines around it maybe not and the lines in the filter have swageloc fittings as do the ends for the tank side converted to AN flare the ends on the motor side are straight tube and will need ends.
I spent around $475 for the lines shipped $130 for the filter and probably $100 in swagelocs thats just over $700 i would like to see $500+shipping for the whole deal with the filter all is brand new never see fuel.
You will need to do some customization to both ends on the fuel system to fit the lines and need bigger frame clamps i used rubber lined adel's but they will flow some fuel and never have a return issue!
Remember this is Custom parts so please know you will have some other work to do! and shipping is pricey due to the size so local pick up is best or i can meet a reasonable distance.
