John Griffin
- Mar 20, 2015
I have a 87 GN that is acting like it is running out of fuel or hit a rev limiter anywhere between 3500-4300rpm. This is a constant problem not intermitant. No codes on the scanmaster and everything is looking to be in range... Fuel pressure is set at 43psi with vacuum off and is rising 1psi with every lb. of boost. That is untill it starts stumbling and then the boost and fuel pressure both lower. I have ohmed the coil and they are all reading mid-12s. Spark plugs look really good and are gapped @ .32... I have checked my grounds and do not see anything that is loose
I replaced my head gaskets a couple months ago, while I did this I also replaced the injectors and got a new 5.7 TT chip, removed my EGR, installed a intake power plate, and replaced my stock MAF with a LT1 and translator.
I did look at other threads to try to find out more info but havent seen any solutions. Any help would be great!
