Hi all,
I bought a CZ and BR valvebody because the KC vakvebody I had kept annoying me.
I have the CZ in the car arm, as that should give me the best wot shift range according to the experts.
But, it doesn't kick down like I want it to, it seems like it hangs in 3rd and won't go to 2nd when I'm overtaking someone.
When I manually select 2nd it sometimes goes to 1st gear. Though, my shifter is an original 3 speed corvette shifter, so it might be that I'm not great at feeling which gear I select.
My pressures at idle:
P: 70 psi
R: 120 psi
N: 70 psi
D: 70 psi
3: 70 psi
2: 160 psi
Can't really select first as it's a stock corvette shifter.
Full TV in park is 125 psi, couldn't test D and R as I'm doing this alone.
I do have the transgo shift kit in there, I highlighted what I've installed.
Any ideas? It's great to have the 4th gear working finally, but it'd be nice to perfect these last issues/ flaws.
Many many thanks !
P: 70 psi
R: 120 psi
N: 70 psi
D: 70 psi
3: 70 psi
2: 160 psi
Many many thanks !
