Paul Clark
- May 22, 2003
The guy who is lined up to paint my car just finished a friend's Vette. If you look closely, you can see the sanding marks made by the D.A..
I've done just enough body/paint work to be dangerous. At what stage should I sand on my car to make sure I don't get the same marks. Bet it's on the primer (?).
If so, what grit will remove the marks but still leave enough "rough" for the base coat to stick? Wet or dry?
