GangsterMD
Turbo'd since '95
- Dec 29, 2007
When I put my engine together I was going to use a high volume cover. I did the Earl Brown treatment which included taping sandpaper to glass and surfacing what I'll call the oil pump housing. I ended up using my stock front cover. I had to remove the oil pump housing after the engine was in the car due to an oil priming issue. I thought I cleaned everything good and was carefull with the gasket - but I had a leak. So last night I removed he oil filter, cooler adapter and housing. It had some minor scratches in the surface, so I took 600 grit on glass and smoothed it out till it was what I thought perfect. I put everything back together nice and clean and it leaked worse than before
WTF??? It never leaked before, I can't see any cracks. I used a thick gasket, and have 80 # oil pressure at cold start up. Is that too much? Could the cover have been un true but matched to the housing? Are the gaskets a one time use deal? Since I've had it torqued at least 3 or 4 times could that cause the gasket not to seal? I'm obviously under the impression I can't use any type of gasket dressing right? I remember using some kind of aneabolic sealant on something else sometime?
D
D
