Mike T
- May 3, 2013
I bought a Danko front bumper once and it did fit ok with the body BUT the "ears" to mount the front parking lamps were not moulded right and I never was able to make them fit right.I sold it, bought a second one (because Danko refused to replace it) and guess what…it was as bad as the first one!!
I got fed up, sold it again, took a loss and decided to go back to the original steel (one from on which I removed the rear reinforcement).
This is why I'll never recommend Danko products to anyone ever!
Claude.
I had the same problem with their front bumper. The mounting brackets were installed in such a way that only two bolts on each side would line up. Returning it was going to be a problem so I cut them off and moved them inboard about 4 inches. Also the turn lamps/bezels do not fit correctly causing them to stick out 3/8 of an inch. The good is that it doesn't weigh very much and the overall shape of the bumper was decent.
