My trouble with pan gaskets started a few years ago. Once was the time the only time the tranny would leak is when I'd pound on the car real hard, several times, didn't leak if the car was driven normally. I should have left well enough alone.
I decided to change the tranny pan gasket last spring, and installed a cork gasket. that leaked/seaped any time, figured I did something wrong.
Took it to a local tranny shop that specializes is high performance applications and they installed one those composite, paper like gaskets. It leaked!
Took it back to them, and they replaced that with a good cork gasket. It leaked! argg! There seems to be a tiny bit of seapage all around the gasket, but primarily from 2 or 3 specific bolts. ?????
I'm tired of this so my last resort is to pull the pan myself again, and this time do it with "The Right Stuff" form a gasket.
Will this work I wonder. Sure hope so! I'm out of ideas.
I thought the bolts were all supposed to be "blind", but this time I'm going to have to try and see if the 2 or 3 suspects may not be as blind as I thought, maybe some small cracks developed around the bolt bosses.
I don't know, I'm stumped.
Oh, BTW, its a deep aluminum pan. last inspection it checked flat and no visible craks.
