Scott,
Yes, the trim bezel just snaps in/out with metal clips. As the guy above me said, just work your way around and it will pop loose. From there you will need a 7mm socket for the small bolts (x4 I think?) that hold the cluster in place. From there you just pull the cluster out far enough to reach behind the cluster to give the bulb socket a 1/8" turn. Also helps to take the grey trim piece off as well. It uses the same 7mm bolts and just unscrews and can be lifted around the steering column and wheel. That will give you some more room to get your hands back there. The resistance you will feel when pulling on the cluster is the speedo cable, RPM/boost cluster wiring, and digital-to-analog VSS window and wiring...so don't pull it too far out.
Did yours go out or something? If not, I wouldn't mess with it. I still have the original one in mine as far as I know and it still works like a champ.
