there are two connectors and they arent the same
easiest way to go from analog to digital is swap the dash harness
engine side harness is the same for analog and digital but youll need to install a map sensor in place of the hobbs switch on passenger fender if yu want the analog boost gauge to work
and the sender in the tank is calibrated differently , the analog uses a 0-90ohm sender the digital is 0-120 ohm , if you dont swap it wont be accurate.
