Dash Harness
smallv6
Still in Block Learn Mode
Does anybody know which wire is for which function on the dash harness that is soldered on to the tach/boost led set-up.
They have the letters A through H on the clear plastic connector.
Could someone tell me what each one controls.
From page 8A-80-4:
  • A - (PNK/BLK) power from 20A gauges fuse
  • B - (WHT) tachometer input from CCCI (thru C100-A7)
  • C - (BRN) power from headlamp switch (headlamps on)
  • D - (GRY) power from inst panel 5A fuse (panel lamps dimmer)
  • E - (BLK) ground
  • F - (GRY/BLK) bias voltage from turbo boost gauge sensor (MAP?)
  • G - (LGRN) boost gauge signal from turbo boost gauge sensor (MAP?)
  • H - (BLK/WHT) boost gauge ground from turbo boost gauge sensor (MAP?)
HTH,
