Dave Bamford's 4.8 LSX Conversion
I have a question for you if you're still tuned in.
What kind of exhaust does this car have when it's running through the pipes?
It has a single 3 1/2 exhaust. 4 inch down pipe with a exhaust cutout prior to the single 3 1/2
Thank you. So there's no mufflers just straight through? I was worried about my 4.8 not sounding good but yours sounds great.
I'm assuming on that highway pull video it's open dump?
It has a straight thru 3 1/2 borla muffler.
I just watched the video, dump was open
The 6 bolt trick flow 235's showed up today 2 weeks after ordering for only $2800!
Dave .....your ride is a lsx beast!!!!..I seriously think you can take on the street outlaws and shake down the list....
Nice build. Have a few questions about the 4.8 engine. Do you think if the rings were replaced with new ones they would not of failed? Also are you limited by not running a intercooler?
The piston is what fails in the end. If you put a set of Wiesco or Diamond pistons and some Molnar turbo rods in the stock block with the stock crank, it makes for a very reliable combo that can make a lot of power,
