SignUp Now!Just installed a new Scan Master spits out correct info but will not recall. Makes it hard to tune. Need advise Thanks! Chavo
the 2.0 coming on for a second is the self test. If it does not display after that it usually means it is getting no data from the ECM. If the connection is good try another ECM or send it to us for testing (no charge)
Mike
Reads 4.58-4.60. Mashed to the floor 4.60.
Went over like you mentioned and registered. I would log in and it would say thank you for logging in. Go to write a thread and then it would say you are not logged in. One time I was writing and introducing myself as they suggest went to send and message and it kicked me out. Your not logged in. My ScanMaster won't recall and Full Throttle who makes the SM kicks me out. Having logging problems.
Maybe you could start the thread by asking the same question for me and then at least I might get some responces as to why there is no recall. Appreciate it if you'd do that for me .Thanks Chavo:biggrin:
Thanks Mike will do. I'll go out later and try another WOT run.Mike in just checking static TPS setting i.e. ignition on motor not running I get .42 and 4.60. One of the runs yesterday I thought I had her smashed to the floor in 3rd and I saw 4.5 degrees and backed off immediatelyand that was with alky on, hit recall and notha. Next run I maxed out alky and did a WOT run in 4th no knock, but no recall of 02's. I'll turn down the boost and put my foot thru the floor board and see what happens. Thanks for your help sir!
Crank that thing up to 23# and 23degrees!!
