Dead Stage 2
Since you're on a roll if you wanted to work on Supras you could steal Harold away from the Bogosians.Just think how rich you could become. lol Lou
I wont have it long enough for anybody to work on it Lou.. :p it should be going up forsale very very soon. :)
Typical outcome of the socially unaccepted.
I dont have to build up a 2,000hp car just to get noticed and perhaps get a little attention, if your going to make a comment like that about me, perhaps it is time you go look in the mirror and reflect back on your comment, I think it suits you more than it does me.. ;)
Chiao.. sweetcheeks..
Thank you!!! Jeff for all the work you have done,,,
Were is my Limited????????? J/K I know its almost done...........
I got it running last night. Ralph did you always have smoke coming out of the vents in the car? If you drive with the windows down and a gas mask on, you can get through it.
Jeff
Jeff
All of Rafael's turbo Buicks have always smoked out of the exhaust before? He's never had any that haven't smoked before, has he?
Jeff
Busted heater core?
Ralph is never broke! Just put a Limited up for sale cheap and see how fast he shows up at your door. ;)
Neal
Update:
ATR headers do not work with TA heads. TA lays the spark plug over for better spark distribution but it then interferes with the header pipe on the #2 spark plug position. You cannot get the spark plug socket on the plug to remove it. Also the spark plug boot contacts the pipe. So we have remove the header and cut up and reposition the tube to correct the issue.
Jeff
Use a special header type spark plug socket and an angled spark plug boot. That would be much easier. Chad has a plug socket set off the tool truck that is the shortest I've ever seen.
Is Chad working with TA heads? I tried different spark plug sockets and tried to modify one but they did not work. I did not want to go through all the trouble of removing that header but after speaking with a few people it seemed like the only option. Reg had his ATR header modified and he still has to use a special socket.
Jeff
