Lol, we do think alike.I threw mine in the trash because that shit is ugly...![]()
You don't need the cooler.the car will run fine without it.So if the car is not tracked, rarely driven except sunny days and rarely hammered on is is safe to delete the oil cooler? Oil is change every 1000 miles or so.
I did not plug mine off.What size plugs are needed to plug the radiator connection points?
I use Wix 51036. Came recommended to me by other GN owners. Napa carries them.I'm guessing I have a bigger oil filter/adapter, because when I took the oil cooler, off my filter would not fit. what filter number do I use when I eliminate the oil cooler? the factory filter?
Nice to know. I'd like a big filter.Or, once removed, add a "biggie" adaptor (available from many vendors here) and use the WIX 51143 or Napa Gold 1143. Both made by WIX.
This is my set up.
