Sep 11, 2001 #1 T Turboaddict Guest has any one using denatured alchy ever mix it with water? would mixing it with water provide a better cooling effect?
Sep 12, 2001 #2 salvageV6 Daily Driver Joined May 25, 2001 Messages 21,009 I mixed my denatured about 50/50 with water and a squirt of WD40. Didn't like the way it corroded the pump outside, and wiring, when I checked the thing out cause my pump fell off the line. Only had about 3 tankfuls of the stuff in there too. I'm sending it back, warranty (thanks Steve), for the brass mods. and see what he says about the pump. I think I got bad denatured it had 4% methanol don't know if that's standard or too high. ??? I'm gonn run iso. and water when I get my new kit and the upgraded kit for my 2 cars. Just my .02. Always look in the tank before you fill it up, make sure everything looks ok.
Sep 13, 2001 #3 S Steve Wood Active Member Joined Jul 18, 2001 Messages 2,338 sounds about normal for the meth. Methanol loses its corrosiveness to a great degree with the slightest amount of dilution.
Sep 13, 2001 #4 salvageV6 Daily Driver Joined May 25, 2001 Messages 21,009 Gonna wait to see what Steve C. says. I should probably have just used alky. and water to see how far I could get with that first. New kit should be here soon, Group purchase deal. salvageV6 needs a drink bad.....
