detonation with denatured at 10psi boost
the wrath
i think i am having an issue with my ramcharger fans drivers side blows hard pass side works but not as fast as drivers and it is blowing hot air on the air filter.
scanmaster readings are
af 03
l8 29
bat 13.6
int 128
bl 124 at idle in park 127 cruising light throttle
clt 187
ats 143 if i am sitting in traffic it flashes hot then when i starts moving it goes to 143 again
rpm 875
tps.44
iac 37
i dont know what is going on here i dont know how much knock retard i am getting but my caspers audible knock detector goes off and the knock gauge was in the red i let off the throttle.
I doubt its detonation unless you have a major timing issue like the interrupter ring has moved several degrees.
Bring it by, I will help you with it. Bison, this guy freezes up, eyes bulge, and cracks the gas at 13psi on a clean run. I bet its false knock, this is his way to justify keeping the car at 8 psi. Put him behind the wheel of a 12.50 car and he will think its a TSM car without a cage.:D :p
Id still check the ring. Ive seen them loose:eek:
I will start checking those rings. He did find a broken drivers side motor mount though.
