DFI Gen 6 SEFI SFI
Pox
Neither small nor chicken
accel SFI Gen 6 unit, very rare, fires injectors sequentially rather than batch fire or bank to bank. Also, with this there is no need for a VIC (varriable injector controller). It should work fine with newer computers, just make a small partition and install a DOS based operating system (i.e. '98 or older) $600 + Shipping
it comes with 3 bar sensor and adpter to stock buick harness. i was using it with 72 lb injectors on a 2 bar map
I'm interested? I don't know anything about what it takes to make a dfi system work. do you have the injectors? I have a stock GN and I'm looking to upgrade. I'm looking for a 70 turbo,f/m intercooler,injectors, 3600 stall converter,3.5 thdp, and I'm sure that I will probably need others.
I have the injectors, a flow matched set of 8 72 lb injectors. You'll only need six but I'll give you all 8 for $300 - they only have 500 miles on them
I know this is an old thread but........do you still have the Accel VIC and/or the set of 8 #72 injectors? Thanks.
Joe
