Skillet said:Following up on this: I bought a used power master from a board member. I changed out the pump today and now I can stop! Thanks YI Work for selling me a working power master system. Also thanks Aminga for answering all my questions and talking me out of buying that accumulator ball. I would probably still be on the waiting list. Now I have a extra and a sensor!
Skillet, let me jack this thread for a little idea I have.
Do you still have the old one. Up for an experiment with an automotive electric motor rebuilder I know?
If anyone's tried this chime in. When you look at the powermaster it's a pretty straightforward piece. It's for the most part a regular brake master cylinder with a hydraulic booster rather than a vacum booster. If you look at the body from the narrow part forward it's a plain old hydraulic brake master cylinder and it's rebuildable just like one. From that bulge back toward the firewall it's a hydraulic brake booster but even that's not that complicated. And that's rebuildable too just like a master cylinder.
The trouble spots are the accumulator ball, It uses nitrogen behind a diaphrma to keep the brake fluid under pressure. You see the brake fluid isn't compressible and the motor can't pump fast enough to keep the hydraulic booster under pressure as you step on the brakes and the piston in the booster moves forward. That's what the accumulator is for. Unfortunatly it's the diaphram ithat starts leaking allowing the ball to fill up with fluid so it can't keep up as you step on the brake. Unfortunatly you can't rebuild those but Cardone is apparently doing it for Kirbans.
That leaves the pressure switch. Don't know about those but it's just a pressure switch (that can withstand brake fluid)
The motor doesn't appear to be too much more than a 12 VDC electric motor much like a starter and those can be rebuilt.
