Differential cover bolts
87national55
Does anyone know if all 10bolts are the same thread and length or do we have (1) that is different?
all of out bolts are same but thts not to say that cover was meant for the 87GN , some 8.5s (f body) had the brake distribution block under one bolt so you may have one bolt thats too long and would need to use a sleeve spacer on that bolt
That was my original thought but since the original bolts were not going in I figured that may not be the case. Unfortunately I have misplaced 4 of the 10 bolts so I was not sure if (1) of them was different then the others.
A quick tap did the trick, so for whoever didn’t know, yes all bolts holes are 5/16-18 if you ever need to know.
