SignUp Now!One is darth vaders car, one is aunt Betty's carj/k
Wanna race, "Darth"?![]()
Darth,I AM YOUR AUNT BETTY!
And I thought you were straight.Darth,I AM YOUR AUNT BETTY!
The Ttypes have lighter wheels (aluminum) than the GNs. The inner bumper braces on the Ttypes are usually aluminum and therefor lighter than the typical steel bumper braces found on most GNs. The Ttypes usually have less options than the GNs which makes them lighter.
Ttypes are lighter in weight than GNs but have the same drive train.
The 86-87' GN was the Anniversary car for the Last Rear Wheel Drive car from Buick less there Power Wagon.(Why they made the car so fast). T-Type's where the Knock-off's of the GN's if you didn't want the Anniversary car.
(P.S.,I'll Except all races from Aunt Betty's!!!,But at the end the 1/4 mile there's a Road Course to Finish too...8^)...)
Enjoy!
They did use primer,however the metallic paints they used where such crap. If your Ttype was painted White or black you might stand a chance of keeping the factory paint job.I've also heard that the reason most Regal Ts are not black is because black paint is heaver which also makes Grand Nationals (all black) slower and they didn't use primer on Regal Ts to further reduce weight! The combination of no primer and thinner paint resulted in more rust holes, again reducing weight. That is the REAL reason Regal Ts are quicker than the much heavier, slower (black) Grand Nationals!
