- Feb 18, 2006
You should look into a pcv catch can system because no matter what you do oil will be sucked into the intake. Get a good inline check valve too for the pcv. Go to a hydaulic hose place and ask for a low pressure 1/4" npt check valve with hose barb fittings
X2 just make sure it has a 0-1 psi crack pressure.
